Kills 99.9% of germs...
So, my secret santa got me...
... herpes. :o
It's their own arse covering, the one that makes you ill will be the one they didn't cover
I heard also that hiv can be killed with just soap, outside of the body it's very weak
its just to cover themselves legally, or maybe it just sounds good - they certainly cannot say 100%.
you can easily detect 99.99999999% kill and i have done it, despite what Qi said on an old episode.
Virtually all viruses can be killed in this manner, proper cleaning, no secret antivirals, no magic sprays, soap and water will kill virus in droplet and blood spills. Outside of body cells viruses are weak and easily disrupted, once inside, then it becomes more difficult, as host cells have to die to eradicate the infection.
A syptom of HIV as far as I'm aware, yes. Although I'm far from an expert so I'm happy to be corrected/educated. :)
I suppose you could see it as a symptom, however it's not exactly a symptom of HIV. AIDS is a separate disease from HIV. Very often, HIV leads to AIDS, but you can get AIDS without ever having had HIV in your life :)
You can have HIV without ever contracting AIDS, that is not true the other way around. AIDS is caused by HIV, it is not caused by anything else. You cannot contract AIDS without HIV being present.
Acquired : means you can get infected with it.
Immune Deficiency : means a weakness in the body's system that fights diseases.
Syndrome : means a group of health problems that make up a disease
so its what we call the symptoms of the HIV virus, which can be nothing to loads of issues... I htink the confusion is because HIV can be ??inactive?? and do nothing at all... (not sure if it literally does nothing or is just kept at bay by your body without much effort)
