*** The Official HTC Desire (Bravo) Thread! ***
Just reading the instructions, sounds scary
Actually dead easy. I did it last night.
Download the iso from alpharev and Universal USB Installer
Run the latter and choose any linux distro, point to the iso and let it build your usb stick. Reboot your laptop (or use another PC like i did) and boot into USB stick. Connect your Desire whilst its actually running normally (and in USB Debug mode), let the software do its thing.
You are now s-off'd. Download the Oxygen img file and use the Android SDK, command prompt yourself to Fastboot.exe and use the commands to push the img
Took maybe 5 mins
bootable cd for me.
external usb dvd writer, boot off cd. hook up phone to computer, press a button - done. took about 2 mins in total.
RC5 out, you know the drill :p
Added animated sync icon (courtesy of ClassicalGas)
added battery percentage (courtesy of ClassicalGas)
Added long press volume to skip track mod
Enabled sip calls over 3G
Implemeted ability to move any app to SD-FAT via applications menu
Implemented backlight control and custom light filter settings (Settings > Display)
Moved market downloads to /sdcard due to increase in max application size in the market
Reverted graphics changes introduced in RC3 to speedup launchers
Updated to Android 2.3.1 R1 (GRH78)
Updated kernel (courtesy of thalamus)
Updated zeam launcher
Other minor bug fixes
