Couldn't get that to work with Videos properly, using UPnPPlay and RockPlayer, is playing everything I throw at it with no stutters.
Most definitely. More app memory (like 10x as much), faster, GPU is 2x more poweful, bigger screen, thinner (by a tiny amount) and 4 point multitouch instead 2 point which doesn't even work correctly.Hi All
My friend is looking at buying a Desire or Desire HD sim free. Is it worth spending £100 pounds more on the HD.
Thanks for the tip! - since using UPnPPlay I can watch all my media
You sound like a person who owns a Desire HD? I've had a hankering for a Desire for ages now. When you say the Desire HD has a bigger screen isn't the same resolution as the Desire? So over a larger area it wouldn't look as good?Most definitely. More app memory (like 10x as much), faster, GPU is 2x more poweful, bigger screen, thinner (by a tiny amount) and 4 point multitouch instead 2 point which doesn't even work correctly.
Desire is a good phone, but Desire HD is an excellent phone.
Not trying to wind you up, just interested in determining whether the Desire is still the phone for me or if I should get Desire HD or perhaps even wait!![]()
Think I do need to go window shopping.The HD *is* rather large, but it's vastly more powerful. Best bet is go into a shop and handle one. It's borderline too large for a lot of people, I'd imagine. The screen is lovely.
I read one review about the Desire HD which said it was very heavy, perhaps too heavy the reviewer thought. Or is it not noticeable, or if it is, worth it?
OK. Cheers.For me, as a regular adult male and not a 5 year old kid or a girl, the weight of the HD is not an issue. It's big so obviously it's relatively heavy but, not so as you pick it up and go "woah" or anything. It's perfectly acceptable.
That's what I like about the Desire! Does the Desire HD not have a direct replacement for the Desire's optical trackpad? Or is the Desire HD controlled on screen apart from the touch sensitive buttons at the bottom?Struggling to see how the Desire can trump the HD aesthetically, though. It has that nasty asymmetrical button arrangement at the bottom, whereas the HD is just sleek with some touchscreen icons.
Cheers. I've just had a look at some hi-res pics of both phones and I'm starting to have fewer problems with the Desire HD. I'm planning on going to Milton Keynes shopping centre sometime next month so I'll pop into a mobile phone shop and try the two phones out then.The Desire HD is no more trouble to use and handle than the iPhone 4 or the original Desire.
It isn't a great deal larger and you gain a considerable amount of screen size with it among many other things. It isn't honestly a problem, dont worry about it.
Hmm I must admit you're helping me move towards the HD now.Interface wise the HD has a power button on the top edge, volume rocker on the left edge, and the touch screen. No need for a daft optical thing, the screen's amazing. The four "buttons" at the bottom are part of the main touch screen slab, but are physical icons with lights behind them, they don't change or anything. With the structure of the thing the screen takes up the vast majority of the visible facia, which helps make it look so sleek and kinky. Compared to say, the Galaxy S, or the Desire, which both have more non-screen space by far, it just oozes quality and high-end-ness, which is an actual word.
Oh and a word on the power button: it's placed on such a perfect angle on the rounded edge that you can hold the phone with 0% risk of accidentally tapping it, but if you need to tap it can 100% always get to it easily. It's a genius-ly precise bit of ergonomic design.
The keyboard does have 4-way arrows which are handy for this kind of thing.I actually miss having a track ball/pad, does make it easier to move 1 character across when typing texts/emails etc.
Just wanted to second this. Possibly the desire can do it too or be upgraded to, but the text reflow on this hd is just amazing. Zoom in on any text on a web page so the font's a comfortable size and it'll alter the paragraph width automatically to fit the width of the display, it's a genius system.The extra screen space is very welcome when browsing the internet (makers it much easier and pleasant) even though the resolution is the same.
Might check out the rooting scene for the HD and see what that's like.![]()
There isn't really one at the moment. There was a temp root which stopped working after the last OTA update a few days ago but I'm not sure what's going on at XDA regarding a perm root. But after 3 months of having one, screenshots aside, I can honestly say I don't miss rooting/using custom ROMs at all.
