The man at the start wanted a 3k estate suggestion, someone said a Mondeo, someone said a Saab, im not seeing the huge difference in running costs or reliability.
Some people hate them i think they are great if i was skint i would without doubt have a Saab. I dont see it as a bad suggestion at all.
I put you more in an x-type or an old xj myself.
Nah if your skint your skint, Jags cost money to keep them right plus petrol![]()
I would have thought the x-type would have been reasonable?
What would you have if you had 3k?
I thought 3k didn't really buy an X Type worth having?
Yea, fair play. Reading it back it does sound very highly strung. My issue is that the negatives of Saabs or Mediocre tyres aren't being conveyed. They're being touted as brilliant and suitable for all applications.You want to calm down mate, they are called opinions.
As for your Saab slating, i do see them as a Mondeo alternative, maybe not a 3 series equal but lets have it right they didnt exactly set the world on fire until you put the bigger engines in them.
And there's the issue. 'nothing wrong with them'. Ok then, lets all have UniRoyals. After all they've done ok in ONE test. Against hankook and kumho.Uniroyals are a budget tyre - they are owned by Continental Tyres so are designed to compete against other budget tyres like Kumhos and Falkens.
There is nothing wrong with them, they are not high performance tyres, but we're talking about Saab Estates and such like, so chances are they are going to be driven somewhat less than enthusiastically and they will be fine.
Its not as though Nangkangs or Linglongs have been fitted. its the cheap chinese junk thats lethal and no excuse for.
I accept that mate, but that's not what is said most of the time. Anyway, I've had my rant, I'll shut up for a while now.Sudden love? What on earth are you talking about? Tyre wise this is the most snobbish forum I'm a member of. If you suggest for a second that you're going to fit tyres that aren't Michelin, Continental or Goodyear you better be prepared for an internet based fist fight for a couple of pages.
There isn't any "sudden love", just rather some people being more open minded and realizing that people putting on the likes of Uniroyal, Kumho and Toyo on their car is still a far sight better than getting the local tyre place to bung on the cheapest set of Wanlis or Linglongs they've got.
Of course this is decent advice. If you want relativity cheap tyres with wet weather performance as a priority you could do a lot worse than Uniroyals, just like if you want a Mondeo alternative you could do a lot worse than a Saab. Sometimes I think people here forget that some of us don't buy cars just because they make the most sense on paper.
[TW]Fox;18115790 said:And Saabs are no different.
So, back to 2.0 Mondeos, which are cheap as chips to buy, run and maintain...
Seriously mate be an expert on what you are an expert on, Saabs and Mondeos are no worse than each other to run, your talking about a tenner here and a tenner there.
[TW]Fox;18115838 said:I beleive you are wrong.
A Saab is, no matter how short it falls of the mark, a premium car. It is aimed at people buying Mercs and Audi's (And ends up hitting the market around about Volvo) not Fords and Vauxhalls. It's better built, it's better made, it has better performance and it has a higher end range of engines.
It is therefore a more expensive proposition to own than a run of the mill Ford, whether you like it or not.
[TW]Fox;18115863 said:Problem with agreeing to disagree on the internet on this is that if Mr 'I only have £3k for a car' runs out and buys a Saab 9-5 Estate with a 2.0T engine and then suddenly finds it's a complete nightmare in our world of £1.20 a litre fuel etc etc then we can sit here and laugh yet he's stuck with the thing...
He wants a cheap family estate not a 200bhp 'premium' car.
