Also running a Q6600 @3.2Ghz. Idle temps are @25 deg when browsing the net etc, using an Arctic Freezer 7.
How have you got such low idle temps? What's your load temps like?
DO IT!!
Also running a Q6600 @3.2Ghz. Idle temps are @25 deg when browsing the net etc, using an Arctic Freezer 7. I went from a 36Gb Raptor to an OCZ Vertex 2E 60Gb last month and the overall system performance has been quite staggering. Best thing I've bought for the PC for ages. Highly recommended.![]()
How have you got such low idle temps? What's your load temps like?![]()
Quick test, just over 20 mins. The fatal error thing in Worker #2 happened just before I took the screenshot. Don't ask me what it is as I've no idea what it means!!??.
.It means your core 1 failed as you can see in the coretemp with 0% load. You need to up the core voltage.
