Poll: So what P67 motherboard are you thinking of buying?
What P67 Board brand are you thinking of getting?
  • Total voters
    312
Found this ASUS P8P67 mobo for £134.22 release date 06/01/2011
Technical Details
Main Specifications
* Product Description: ASUS P8P67 - motherboard - ATX - iP67
* Product Type: Motherboard
* Form Factor: ATX
* Dimensions (WxDxH): 30.5 cm x 24.4 cm
* Chipset Type: Intel P67 Express
* Multi-Core Support: Dual-Core / Quad-core
* Processor: 0 ( 1 ) - LGA1155 Socket
* Compatible Processors: Core i5, Core i3, Core i7
* 64-bit Processors Compatibility: Built-in
* RAM: 0 MB (installed) / 32 GB (max)
* Supported RAM Technology: DDR3 SDRAM
* Supported RAM Integrity Check: Non-ECC
* Supported RAM (Registered or Buffered): Unbuffered
* Storage Controller: Serial ATA-300 (RAID), Serial ATA-600 (RAID)
* USB Ports Configuration: 16 x USB
* Storage Ports Configuration: 8 x SATA
* FireWire Ports Configuration: 2 x FireWire
* Audio Output: Sound card - 7.1 channel surround
* Networking: Network adapter - Realtek RTL8111E - Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth 2.1 EDR
* Manufacturer Warranty: 3 years warranty
Extended Specifications
General
Expansion / Connectivity
* Interfaces: 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) ¦ 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) ¦ 1 x audio - SPDIF output - TOSLINK ¦ 1 x IEEE 1394 (FireWire) - 6 PIN FireWire ¦ 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 ¦ 2 x SuperSpeed USB - 9 pin USB Type A ¦ 6 x Hi-Speed USB - 4 PIN USB Type A ¦ 1 x audio - line-out - mini-phone stereo 3.5 mm ¦ 1 x audio - line-In - mini-phone stereo 3.5 mm ¦ 1 x microphone - output - mini-phone 3.5mm ¦ 1 x audio - line-out (side surround) - mini-phone stereo 3.5 mm ¦ 1 x audio - line-out (rear) - mini-phone stereo 3.5 mm ¦ 1 x audio - line-out (centre/subwoofer) - mini-phone 3.5mm
* Service & Support: 3 years warranty
* Service & Support Details: Limited warranty - 3 years
Miscellaneous
* Compliant Standards: Plug and Play, ACPI 2.0a
Where did you find that at?
i think im going for the ASUS P8P67 Pro ,its on sale now for £135 inc vat in certain places - all i want is an entery level with sli (hoping the 2500k isnt going to break the bank :D )
come on ocuk give us some prices ;)
all the best mike
They can't give us prices, NDA.
But its estimated the i5 2500k will be 170, with the cheapest motherboards being about 100.
Some Motherboards are already released here in Switzerland but the CPU's are not.
Can not compare prices to Uk as the exchange rate is completely screwed just now. Used to be £1 = 2.4CHF but now =1.5CHF.
I will be getting the P8P67 Deluxe, which I can tell you is around £20 more than the EVO version here. Price is 238ish CHF for the Deluxe which depending on exchange rate is 100 quid up to 160 GBP. My biggest problem is the lack of DDR3 memory in stock, I need to decide what to get and order it first as there my be an even bigger shortage soon.
I'm liquid cooling it at the moment using a 1156 block. I can confirm that the spacing for the coolers of 1155 is identical to 1156 (8mm)
Ah ok I was just trying to get ideas about air cooling as i noticed you were getting 4.8.
So have you tried for more than 4.8 as your not on air? i thought you'd be able to get 5 on liquid?
oh whats the max multiplier the 2500k has?
