First impressions - OCZ Vertex 2E
Just installed a 60GB OCZ Vertex 2 yesterday, install and set-up was pretty easy, Didn't have to tweak much of anything ...
1. I Enabled AHCI in BIOS before installing Windows 7
2. Then installed the latest Intel Rapid Storage Technology
drivers from here http://downloadcenter.intel.com/Det...oductProduct=Intel®+4+Series+Chipset&lang=eng
3. Installed latest drivers for my GFX Card
4. Disabled Windows 7 Defrag
5. Ran this command to enable Windows 7 Trim "fsutil behavior set disabledeletenotify 0" (without the quotes)
6. Enabled Write Caching *(tweak see below)
7. Disabled Hibernate in Windows 7 *(tweak see below)
8. Changed the Power Plan to Maximum Performance which should help with SSD garbage collection *(tweak see below)
9. The last thing I did was run Windows 7 Experience Index where the OCZ Vertex 2E scored 7.8 in Disc data transfer rates.
* no other tweaks were applied, but there's a list on OCZ forums you can try for yourselves. http://www.ocztechnologyforum.com/f...3-*-Windows-7-Ultimate-Tweaks-amp-Utilities-*
OCZ Vertex 2E SSD v Samsung SpinPoint F3 1TB SATA-II 32MB Cache, both drives had fresh installs of Windows 7
ATTO Benchmark - Vertex has firmware v1.25 installed
Rebooting from desktop > back to desktop
WEI
Temps
WEI
Temps
