Lottery question
Lucky dip for me :)
Although theres no reason those numbers have any less chance of coming up than others :)
Yup.
But you'd probably have to split it with far more people as I'm pretty sure more go for 1, 2, 3, 4, 5, and 6 than what your lucky dip would go for :D
Do you have a bigger chance of winning if you use the same numbers each time?
In theory, if the draw is done 14 million times, each combination comes up. If you do 52 draws each year then in a lifetime you could do maybe 3000 draws. Now over that lifetime is it not more likely that your chosen number would come up once over that period, rather than you having a different number each time?
Also can someone post what the numbers were they aren't in the internet yet. Thanks.
Try bbc red button
