Just over a mile or so away from home, felt shuddering under my clutch foot, then smelt burning, then saw smoke from the bonnet and quickly switched off. Gearstick was locked into first gear position, but after a minute or so it freed itself. But then clutch pedal lost all springback and is completely loose, dropped to the floor without returning. I thought it was a cable but the AA man said they're all hydraulic. He pointed to the road and showed me some fluid leaking, and said the slave cylinder was leaking pressure. He said they have to remove the gearbox so I might as welll replace the clutch. I'm hoping it doesn't come to more than 5 or 600 quid. I believe Mr.Clutch is very cheap hourly rate, but there isn't one nearby.
Just got a tow to the nearest garage, a citroen/peugeot specialist and MOT centre I use, both next door to each other. I'll ring them both tomorrow, see who's the cheapest, or, who can get it done this week.
Oh, 307 HDi, 2001.
Oh, 307 HDi, 2001.
