- 19 Jul 2010
- West Oxon
If your fixed on a plasma, and i don't blame you much prefer them too .... then there really is only one choice, Panasonic.... they paid a LOT of money last year to get the rights to the pioneer KURO research and design when pioneer pulled out of the plasma tv market, as a result they are producing probably the best screens these days bar none.
which model is tricky, because of the costs involved, if you want the best screen right now, without going to 3D then the Panasonic TX-P50V20B can be had for about £1325, however, John Lewis are doing the 46 inch VT model, which is 3D with a free 3D DVD player thrown in (£280 worth) and 5 years warranty for £1600 !! so it's not a straight forward choice.
Last year, Panasonic had some issues with the 2009 range loosing their black depth levels inside a year, google it, it will show up, as far as i know this has been rectified for this year, certainly on the infinite black pro range, which are the ones that use the pioneer technology.
Both of those models also come with Freeview HD and Freesat HD tuners built in, which if you ask me is good, and not something to be overlooked these days.
If your budget simply won't stretch that far, the 42" TX-P42V20B (non-3D) panel can be found for as low as £890 with a little help from google
If that's still too much then your looking at the TX-P50X20B ....
http://www.panasonic.co.uk/html/en_...sma+TV/TX-P50X20B/Overview/3507173/index.html
For what it costs (£499.00 is about the best deal right now) the TX-P50X20B represents a good deal for a LOT of tv of good quality, but for me the added benefits of the newer pioneer sourced technology, and the dual HD tuners, make the 42" TX-P42V20B at £890 is a better deal in the long term i think.
There are many things to consider these days with plasma choice, as i'm sure you are aware, especially from your last purchase, someone here has one of the 50" 3D monitors because i saw it mentioned in one of the picture threads, either show us your desk or setup or something like that, you could always ask them
EDIT:
just finished typing all that wwhen i checked the last couple of posts, i see you bought one ... lol, oh well the info can stay there for anyone searching..... so how is it, and what are your thoughts so far ?
EDIT:
