- 12 May 2004
- England
wiimote is better once you get the hang of it as you can peek around corners etc
mp is much fun
mp is much fun
I thought that Metroid Prime Trilogy had amazing controls.
My main issue is the controls, as already mentioned. You can't look directly up or down, which is very annoying. I was hoping leaning round corners would be implemented, but isn't, or at least not that I have been able to sort out.
you press Z to iron scope and tilt with the nun chuck.
There is something very odd about the vertical controls in this game, they just don’t work as well as other shooters on the wii.
I tried this with my kids the other night , very frustrating with the wii motes,i completely lost interest within minutes of playing due to the movement system
might give it a try on my own
It's a pretty good game in its own right, but it is not an original N64 beater.
But I spend the entire time going "but it's not the original"
Oh yeah, and its got the wrong bond in it, in fact, I think DC is a terrible bond.
couldnt get the hang of the wii mote controls. There's novels been wrote about this in various online forums. The wii mote is awesome for aiming, but as soon as you turn it just doesn;t work, you move the pointer to the edge of the screen to aim at a baddie and then your screen starts turning so you have to correct your aim..
It's a weird kind of disconnect between aiming and turning.
Classic controller worked a little better, more consistantly, but tbh, playing fps on a controller sucks. Could have been a great game, but marred by really bad controls imo.
The other thing is when you zoom in and then come back your screen jumps all over the place as it 're-aims' based on the current position and not the position you were in before.
If it was possible to use a mouse + wiimote or usb keyboard this would be great.
Wii COD suffered the same terrible control input as well I played that for about a level or 2 and gave up.
you should mess about with the wiimote settings you can customise the ass out of it.
Leaning works with wii mote only, you hold Z and twist nunchuck
