So...you've ordered your Sandy Bridge components. What did you go for?
I spent ages deliberating whether to buy now or wait for a little while longer. Then spent ages looking at various coolers and seemed to keep hitting a brick wall with my Antec 300 case and pretty large side-fan. Also some of them don't have enough comfortable clearance for the RAM I wanted.
In the end I went for this lot:
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge)
G.Skill RipJaw 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler
Came in at pretty much bang on £400 after the VAT discount and that's about what I initially wanted to spend. I look forward to re-building my computer tomorrow (with any luck) and saying farewell to my 3.2Ghz Q6600. It has served me well but has outstayed its welcome.
Palit GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card
Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive
Coolermaster CM690-II Lite Dominator Case & GX 750W Power Supply
Corsair Hydro H50-1 High-Performance CPU Watercooler
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz
Palit GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card £225.20
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £155.02
Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) £122.39
OCZ Vertex 2 "25nm Edition" 50GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTX50G) £74.99
OCZ Reaper Low-Latency 4GB (2x2GB) DDR3 PC3-12800C6 1600MHz Dual-Channel (OCZ3RPR1600C6LV4GK) £63.64
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply £56.655
Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775/1155/1156/1366/AM2/AM3) £49.99
Coolermaster HAF 912 Plus Case - Black £48.32
Western Digital Caviar Blue 1TB SATA 6Gb/s 32MB Cache WD10EALX - OEM £43.74
4:30 cutoff point been and gone.... with the order still stuck in security validation :o wouldn't mind but i ordered at 3:50!
You and me must think alike... we are almost identical apart from the Case and ram LOL
Isn't the cut off for the time when YOU should have completed your order (i.e. submitted payment details etc.)?
would recommend 1600MHz ram instead of 1333 though
Do not really need it as i5-2500k is a multiplier overclock (in the main). I have some Crucial 8GB (4GB x2) on order which is only 1333mhz stuff which will do the job and apparently the Crucial stuff overclocks rather well anyway.
I don't think 1333 vs. 1600 Mhz will affect real world performance (maybe benchmarks, slightly) or overclockability considering the way SB overclocks. I just went for 1600Mhz because I wanted some C7 RipJaw memory and I could slot it into my expected spending (i.e. £400 or less).
Pre order though
I'm working anyway but have 5 days off starting Wednesday so it doesn't bother me if its a few days late considering I saved like £50 and can't do anything with it all until my day off.
Anyone ordered from OCUK actually been told it has shipped yet?
Yeah mines gone although I will be getting it a bit later then most as I am in Channel Islands and used DPD. I ordered about 10 minutes after Gibbo announced there arrival ie about 13:30
