Business Cards?
21 Oct 2006
Cambridge
Any recommendations where I can get good quality, cheap business cards printed?
I've the designs, I just need them printed - I had a quick search but no-ones asked before!
I should have stressed that i'm looking for quality over cost, obviously I want it to be as cheap as possible, but quality is important to me.
I couldn't find a double-sided option on Vista print, and their paper gsm is bad!
? Mine were fine. You can also get up to 265g/m² for a little extra cost. You can also edit backside/supply own design.
I'll take a look, however most of the places i've been looking at are 400g/m - I might buy a small quality from VP first and if they're okay i'll get them printed
Avoid vistaprint, cheap for a reason!
Moo are great, not cheap but the quality is superb.
I work at b2b printing company so could just print them for free, but I use Moo!
