Vistaprint is shockingly bad quality.
I couldn't find a double-sided option on Vista print, and their paper gsm is bad!
? Mine were fine. You can also get up to 265g/m² for a little extra cost. You can also edit backside/supply own design.
Try Goodprint or Moo.
Isn't 400g/m like 1/2mm thick‽I'll take a look, however most of the places i've been looking at are 400g/m - I might buy a small quality from VP first and if they're okay i'll get them printed
Maybe I'm doing it wrong...About that, yes.
**** Vistaprint. Moo looks great. Just been messing around with it.Cheers guys, i'll like use Moo or Goodprint![]()
