- 9 Dec 2009
- Bristol
I don't overclock and my CPU is duo at 3.00GHz
How dare you!
See what you can get out of it & post your results
How dare you!
See what you can get out of it & post your results![]()
I quite like the looks of that coolermaster too.
The direct contact heat pipes are a nice touch, i wonder if that is what makes them better.
Also might be noted that MX3 paste would better any of these coolers still, right?
I've ordered the CM Hyper 212 +, just curious, is it better to spread the thermal paste out on the cpu or to just leave a pea sized blob and let the heatsink spread it out.
Hey,
Freezer pro with two fans in push pull configuration = big smiles! My i5 @ 4ghz under prime runs at 69 degrees
Not bad for thirteen quid![]()
Hey mate,
Don't laugh but I fed a piece of wire through the fan mounting holes of the extra fan, and pulled the fan tight through the heatsink then used the supplied heatsink fan to clamp the wires at the front. I'll take a picture when I get home but it isn't pretty!! Very functional though, and dropped the temperatures loads!![]()
Hey mate,
Hello, I'm just wondering if this CPU cooler is better than the ThermalTake Blue Orb. I was just thinking of getting a better CPU cooler to lower my heats and don't have much money because I'm a student and was thinking of this one:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-AR
Thanks
EDIT: My CPU package is Socket 775 LGA.
