Hi all,
I just received my 2x 6950's two days ago. After installing them I noticed that in the CCC that when I select one of them the GPU clock is at 400MHz and the memory clock is at 1126Mhz but when I select the other one GPU and Memory are 0 MHz. Is the second card ok?
Also, you know the crossfire bridges. Should I just be using one to connect the two cards or should I use the two bridge connectors? I am using 2x of these at the moment.
Thanks in advance
Thanks in advance
