EDIT:
Greg I am sending you the bill for a minor cardiac arrest .. lol
Are the cards in both blue slots?
EDIT:
It might be worth uninstalling the drivers, running driver sweeper and reinstalling.
I only have one 6950 flashed and run black ops at 1920x1080 maxed out and it copes perfectly. There are no issues or slow down so with 2 on a lower res you should be steaming along.
I had the same with my old xfire set, i had the edit the reg, search for enable upls then i had to change 1 to 0 or 0 to 1 cant remember off hand im not home at the mo but ccc will then show second card idle temp and fan speed after rebooting, if you google for it you will get better instructions
Your drivers are not the same as mine.
I am on 10.12a and they work well with all the games I play.
To be honest I am too afraid to change them at the moment![]()
Best bet is start over again, try both cards on there own to see if there ok, then i would uninstall the drivers and run driver sweeper, then install 10.12a with one card, power down and fit the second card enable xfire and reboot and hopfully it should be working as it shluld
