Great, I found a 12v supply that is for my router, will that be ok? It's 1.5A.
Should be. Check it's an DC adaptor and not AC and that you get the polarity right.
Make sure the router supply is DC, if that's what the radio needs.
Also check the polarity. If it is centre negative and you put a centre positive adaptor into it you could damage it.
I don't really understand the bit about polarity.. it can only go in one way. How do I know if it's ok?
Is there a symbol with a flat line and a dashed line above it on the power supply anywhere?
What does it say on the back actually, or post a photo
I would be amazed if the router power supply output 12V AC.
That outputs AC. If that's the plug you have and your radio needs a DC input, then that will probably fry it.
