i shower at -273.15 C
You're telling absolute porkies.
How could you shower when everything is a solid?![]()
you scrub against the ice and it melts into water with your body heat, then you think of monkeys and wash your mind.
Correct. Crucially, coldness is a relative concept; you determine 0°C to be 'cold' relative to a temperature that you are acquainted with.I've seen a lot of people convert 0 centigrade to fahrenheit/kelvin. Half/double it and convert it back.
I can't help but feel this will yield false results.
When you are describing a temperature as "twice as cold" as another, you mean that the difference between one temperature and a baseline temperature is twice that of the other.
e.g. if we took room temperature (300K) as our baseline, 0°C is 273.15K, so twice as cold is 300-(2*(300-273.15)) = 246.3K, or -26.85°C
You'll note that, unlike many of the incorrect answers in this thread, this produces the same result regardless of scale (celsius, kelvin or fahrenheit) as it reduces the question to a simple monotonic transformation![]()
2c is twice as hot as 1c
-2c is twice as cold as -1c
therefore - 0c can't be doubled.
I think a lot of you are trying to say that twice-zero is colder than twice minus-one.
So the question could easily be what is twice as cold as 273.15 kelvin
But that is a different question. The scale must be specific to the question asked.
You're trying to transpose a human qualitative measure onto an absolute scientific scale.
If room temperature (comfort) is 20c, then 0c is 20c below normal, and twice as cold is -20c.
Simples.
"heat" isn't dependent on scale though.
It's the energy of the atom.
But is human sense of temperature liner?
Or will -5 or -10 feel twice as cold as 0 c?
By that logic, -68ºF should be the same as -20ºC, since 20ºC is 68ºF.
