Don't bother with the bumper.
I had one on mine and grit got between the case and the phone and scratched the antenna band to holy hell.
How did that happen, should be a tight fit all the way around?
I wouldn't be without mine, the amount of times I've dropped it or it's slipped off a sofa etc. onto the floor it would be dented to hell!
Like most cases its best to take them off and give them a bit of a clean to avoid getting crap in there to damage the phone...
Ive had my iP4 cased in a bumper since lauch - not one bit of damage but I clean the case once a month to make sure
ps3ud0![]()
Jesus thats just pure bad luck thenThis is where I get confused.. I was cleaning it every other day before this happened!
when the case program was on. i got that clear belkin case it covers the sides and back. best case ever. just get a screen protector and that and your sorted. no scratching easy to remove no need to cover the back of the phone in plastic to protect it from grit rubs
http://www.belkin.com/IWCatProductPage.process?Product_Id=512038#
Also, why use a screen protector? The glass has a smudge free coating.
