Hi,
Well, after a complete disaster weekend with the new rig build, it seems my Sandybridge CPU may have bitten the dust.
I've had constant struggles with stability and system freezes.
There is a question mark over my motherboard (Asus P8P67 Pro), but I'm not sure if the struggles are due to the chip or the board, or both!
It feels that the stability has degraded over the past 3 days.
I now can't get stable running with any BIOS, either 804, 1003 or 1053, my system freezes in Prime95 after about 1 min now. All settings stock bar the RAM at 1.65v and 2133MHz.
I've seen the feedback from Gibbo on voltages, my RAM won't work at anything under 1.65v, it's recommended rating. I purchased Patriot Sector 5 RAM at 2250MHz based on Gibbo's post here that stated it was compatible with Sandybridge, which I'm struggling to see how it is.
http://forums.overclockers.co.uk/showthread.php?t=18226563
I did manage Saturday and Sunday to run most of the time with the RAM at the correct speeds and timings, under stock conditions and also some overclocked conditions, but would freeze randomly at the desktop or in benches.
Played Crysis and BFBC2 for 30min to 1hr periods ok. Out on the desktop it would freeze randomly, generally after some time.
Temps don't get over 48deg C at load in stock.
So, now the CPU won't TurboBoost above 3500MHz (should go to 3800) if left on Auto, when before it was working on two BIOS revs. Won't work in any BIOS rev now. If I force the Turbo ratio in the BIOS it freezes under Prime load pretty instantly on all BIOS revs.
I've mem tested the RAM and it is ok, but it may be a RAM incompatibility with the board issue mixed in there too, I don't know.
In any case, the system has degraded and I've ran 95% of the time stock settings, bar the RAM as discussed. My highest Vcore was a 30min spell at 1.32v where it ran at 4.8GHz. Temps were really good at 57deg C. Interestingly it ran Crysis a long time ok (a good hour), then exited and was tinkering on the desktop in Internet Exlporer and froze! I tried a 4.6GHz clock with similar results, at Vcore of 1.275v. Then I reverted back to stock settings and trials.
The thread below shows my struggles with the board. Post #52 shows a pic of the 4.8GHz clock.
http://forums.overclockers.co.uk/showthread.php?t=18226900&page=2
So, at first glance it feels like it is a mem compatibility issue, but why won't the Turbo ratio clock up to x38 under load now? I may be clutching at straws here, but is the RAM voltage affecting the CPU's memory controller? 1.65v is supposed to be safe, it also states it in the manual!
I'm going to run the CPU faster but with the RAM on Auto, see what happens.
Feel like returning everything at the mo!!
