- 25 Nov 2002
- Somerset
Dave ignore the Base Clock test Fail.. It will fail that because all motherboards seem to be slightly over the 100.
Yea edit the config and untick the Base Clock test. then please try again. Thanks.
dave_beast Ran that Intel test, and it's fallen over by saying my bclk is faulty, well, the test is faulty!
Simon which of these RAM sticks did you use when testing?
Patriot PC3 - 19200 2400Mhz 2x2GB @2133 9,11,9,27 also OCZ PC3 12800 1600Mhz 6,8,6,24
Also did you try 1 stick test only ?
[/B]Integrated Memory Controller Speed Test Fail. Expected: 0 Detected: 0
--- Reading Integrated Memory Controller Frequency ---
Expected IMC Frequency is --> 0
Detected IMC Frequency is --> 0
--- Test End Time: 01/11/2011 16:16:28---
Ok, now i've run it with bclk test disabled, and it's still fallen over
Thank you ! You just proved now the Motherboard and CPU are working fine for Simon
The Intel test has a bug in it that proves
..Looks to be either very good news (the test is wrong) or very bad news (the mem controllers are all borked) i'd have to guess the former.
Id say it has issues with your memory?
So far we proved in Simons case 1.4v on the core, raising the base clock and setting memory to 1.65v fried his previous chip.
Ok, disabled Base Clock Test and the Integrated Memory Controller test and passed but it still ran the Integrated Memory Controller stress test![]()
Or I just had a bad chip!
I want to see what Overclockers say when they test it
