1.4 vcore - there is your answer. 32nm CPUs do not like this at all, especially if you are raping the living **** outta it.
Just out of interest do you know what voltage is when the asus motherboard automaticly overclocks itself.
I think I have exhausted everything I can. It must be either the CPU or the Motherboard.
I had that with no base clock overclock. wouldn't worry...
Unless the onboard controller can tell when the BCLK has been pushed past 100, even if its in the past... Not sure thats possible though...
I just ran mine again, it fails on a clokc of 99.8mhz... And thne passes when its spot on the 100.0mhz BCLK... so wouldn't worry
did you overvolt the memory controller? vccio? or push the memory voltage past 0.5v + vccio voltage as these can destroy cpus?
Right Simon. If you send me an email. I can sort out an RMA for you and get your board changed![]()
I'm missing something, I thought the chip was at fault?
Well I can do an RMA for the CPU and board then![]()
looks like i am not ordring my sandy then i will be waiting for bulldozer i think or is this down to a bad chip/mobo?
