.... and be ready for a quick getaway if she comes after you.![]()
There are plenty of wooden doors that could be made to fit in quite easily, IMO;
http://garador.co.uk/timberdoors.html
I got 17 foot by 7 above according to the plan if my conversion is right, i was thinking more a desk chair and mini bar![]()
with barI cant see the problem with just opening the doors with side hinges to be honest, is there actually something wrong with ones like in the picture?
You have to open one, then the other, get in your car, drive out, get out, close one, then close the other, lock with a key, get back in your car. Then the reverse when you come home.
That would drive me mad. I'd be lost without an electric garage door![]()
Cant you see if you cant raise the roof a bit, or are planning constraints holding you back?
Are the garages separated orr will it be one big garage?
Needs a blokes room above, all the best ones have that with arcade machines and a pool table, bar and of course pole.
Just not enough room without going for like dormer (squared out, i dont know the exact term) roof, and with the best will in the world where do you draw the line? It only cost 100k to build me sons conversion above the old garages here, 50k on a garage is about my whack i think.Me wifes already gone balistic, she's gonna want something now as well to compensate![]()
I think a nice office space above would be perfect, You still buying and selling cars?
50K this is costing, how much better can you do? Also can you do like for like construction, this needs to last the duration.
