If you like fixing cars you could always make your own inspection pit when you lay the foundations?
I cant see the problem with just opening the doors with side hinges to be honest, is there actually something wrong with ones like in the picture?
They are ok, except when it's windy then they are a right pain, or do can they be 'locked open' so to speak? Do you have the option of electrifying them in that setup?
Yea i phoned this morning electrifying can be done, so im going with that save on the manual labour![]()
get a clock tower on it!
This only works if Mark also owns a Delorean, Doc Brown and knows when the lightning is going to strike.
