Erm okay, I don't know if my BIOS is taking the **** out of me.
I just downloaded this thing called CPUID hardware monitor:
http://www.cpuid.com/softwares/hwmonitor.html
The CPUID thing is saying the CPU core 0 and core 1 is at 20 degrees.
Is the bios just not reading properly or what should i believe?
Okay just downloaded CoreTemp and it's also reading the same thing, 18-20 degrees. I think the BIOS is not reading properly, true?
Edit: So I got this one called SpeedFAN and now it says Temp 1 36 degrees, Temp 2 36 Degrees, Temp 3 43 Degrees, Core 17 degrees. I don't even know what it means by temp 3, it's a dual core not a triple :S
