I'm just about to get rid of mine at the weekend(05 plate, 116k, yours for close to £4k before Saturday
Can't fault it really, only that it was starting to feel like it has done that many miles, up until around 110k it felt fairly solid but recently it has felt a bit loose almost.
Nothing much went wrong (coolant hose popped off, coolant temp sensor broke, glow plugs were replaced) and I never had any real issues with it
)Can't fault it really, only that it was starting to feel like it has done that many miles, up until around 110k it felt fairly solid but recently it has felt a bit loose almost.
Not true. Cupras had them as standard iirc, and FR+ did - but FR's only had them as an option, which my car didn't getFR spec means you will have the Aura CD head unit with a 6 disk changer in the glovebox
