google coolermaster megaflow 200mm £13 or check members market but i dont think u have access yet as i am selling two new red 200mm
im changing the color to blue to match the motherboard.the msi card has a blue sticker as does my psu so it made sense
it comes with 1x 200mm front and 1x 120mm rear.i opted to grab 1more 200mm for the top and buy 2x 120mm apache blacks for the rear and sides.the side slot will take 140mm if you wish but apaches are pre braided which i wanted.i aint gonna color code my rig and have yellow wires running through it
i also reccomend finding a side dust filter, i choose a company called demcflex who do amazing looking medical grade mesh filters, google demcflex for thier website and they come in both white and black mesh.the black looks amazing just remember to order one size bigger than whatever size of fan you choose to mount in that side 120/140mm slot.my reasoning is if using rubber mounts the rubber heads sits out slighty so clearance will give the mesh a little give of a few mm
another upgrade you might want is nexus dampers case feet which u can find via google for around £9.the feet on these cases are all plastic which is bad if its going to sit on a desk.
thats what my case + upgrades to it consisted of and it came to around £125 ish and will kick the ass off the HAF X with all the stock fans and filters and still cost £15 less.
