- 28 Mar 2005
- Newbury
Does Portal 2 even have a competitive mp mode?
Just co-op as far as I know.
Will be so much win if you can buy the PS3 version, unlock the PC/Mac version with it then trade it after. I'm sure they will prevent this though.
Only way I'd consider buying a Valve game on a console, ever.
bring on a cross platform fps!
Have I made a poor assumption and thought this wont be played over PSN as we understand it with normal PS3 games but over Steam - therefore the device accessing Steam is largely irrelevant...
Already been done, Quake 3 Arena supported PC vs Dreamcast games.
I'd have thought the people buying it second hand that end up contacting Steam support with proof of ownership would quickly result in issues for you playing it.![]()
As far as I can work out, you'll log in to Steam to play the PS3 version online and this will be the only way to do it. If you want to play against your PS3 friends, it will be via Steam not via PSN. You will have to re-add your PSN friends as Steam friends - unless Valve import them automatically.
Xbox 360 will use Live as normal - no Steam features at all.
Well theres no clear information but it could be it uses both, after all PSN is the overriding network surely?
I imagine the best way to tell was that they sucked and would get there ass handed to them without difficulty. Since Portal is coop it won't have that issue.
So will the console community want to play with pc people as they use k/m?
