I'd say this, as even though it's £60 it has good cooling and cable management, has the opportunity for watercooling and imo i like the look, there is also a white version for £80 or you can buy a windowed panel for the one I suggested for £15.
I WIN!
. I'm glad you sent the review as I had already wrote the case off without really checking it out properly. Thanks.I have very similar desires for my new case (hopefully this year). I think I've found one that's almost perfect. Only problem may be it's likely not to be an air cooling beast (but WC will fix that or just a decent air cooler tbh).
Corsair's upcoming 650D looks perfect for me. I'm looking forward to seeing them out and around. Good cable management (like 600T, 700D), possibility for water cooling, looks quite subtle but very nice, side window to show off your hardware etc etc.
Only problem is it will most likely be a little out of your budget.
You have to clean dust filters - they collect all the dust that would have gone in your case. So once your dust filter is dusty, your airflow is impaired. Gotta clean them - it's pretty easy (on the P193)![]()
From my travels of the interwebs it seemed like the obsidian series wern't that good for cooling, which is a shame because they just seem to do everything else so well. Though like you say, water cooling would fix that. I don't think I'd consider just settling for a good heat sink as the gpu is what really suffers from the temperatures I believe. But I guess if you arn't overclocking it that isn't such a big deal, though gpu's seem to consistently die for me every few years so I wonder if they are getting too hot in my case.
I'd imagine the new case will come out at £250 plus easily. Don't think I could justify that price.
Cooling for air will still be good, just not the best. I don't overclock GPU, so shouldn't be a issue for me personally, but if you're having problems with OC'd GPUs busting, you might want to dial it down. What sort of temps do you get on load for the GPUs?
The case will be £145! Might not be what you think, it's a lot smaller than the 700D and fits between that and the 600T.
. Though april is quite a wait for me and I have to fit it in with uni as to when I upgrade. Has to come into one of my 6 months off hehe, was planning either in February or Easter, which I guess april would work for.From looking at the pics on the ocuk product description page, the filters on the PC-B25FB look as if theyre accessed in the same way as the full tower A70F i have, literally takes two seconds to get at them, you simply pull the entire front panel off.
best case for £135 ish overall in terms of looks + performance imo that or the Lian Li PC-9F or Silverstone RV02 Raven 2The front panel is detachable and they can be removed without tools.
