so a couple years ago i picked up a vapochill ls off ebay. i got,tested it, and seemed fine and normal. To be tottaly honest i was scared of it
and didint use it until this week. i have heard everyone say that a Q6600 is about the max that a vapo will take in stock form and that my temps would prolly go over 0c and slightly into the positives. Well i mounted it using kneadable eraser,plexiglass and all threads. i got a air tight seal and got the head mount damn near center. upon clocking my q6600 up to 3.8 i have noticed that my evap temp hangs at -51/-52 at idle and under a full prime load only goes up to -41. I know there is a dif between core temp and evap temp but i still cant imagine the core being that far from the evap...????? my moth will only read temps down to 9c, im mounting a temp prob from my multimeter tonight to try and get a reading off the cpu.
i looked inside and there is a sticker on the compressor that says it has R404A in it(thought they had r134). Also from the pics i have seen from the other units my compressor looks bigger? the condesor and the fans seem normal(panaflows).
I will post some pics tonight(at work currently). Could anyone tell me if there was any factory trim of these vapos that could hold these temps on a q6600, it dosent even seem like its breaking a sweat.
maybe i got lucky?
and didint use it until this week. i have heard everyone say that a Q6600 is about the max that a vapo will take in stock form and that my temps would prolly go over 0c and slightly into the positives. Well i mounted it using kneadable eraser,plexiglass and all threads. i got a air tight seal and got the head mount damn near center. upon clocking my q6600 up to 3.8 i have noticed that my evap temp hangs at -51/-52 at idle and under a full prime load only goes up to -41. I know there is a dif between core temp and evap temp but i still cant imagine the core being that far from the evap...????? my moth will only read temps down to 9c, im mounting a temp prob from my multimeter tonight to try and get a reading off the cpu.i looked inside and there is a sticker on the compressor that says it has R404A in it(thought they had r134). Also from the pics i have seen from the other units my compressor looks bigger? the condesor and the fans seem normal(panaflows).
maybe i got lucky?
. father winter came to visit my board but seems to be ok. i just got a 190 cfm 120 delta that will be going on the condenser so im gonna try again for 4.0.
