Piercings on guys
Looks even worse if you stretch it. Also, anything bigger than 6mm and it probably won't shrink so you're stuck with it for life, as if you won't be saggy enough when you get older as it is.
I think it's around 10mm, got friends who have 'normal' lobes after stretching to about 10-12mm.
However if you go any bigger, you either have to get costly surgery where they cut the stretched excess and recreate a lobe. Or 'snap' your ear and get it done free on the NHS I think :p
Belly Button piercing?....
OP are you;
A) A man
B) A woman
C) Neither of the above
Unless you are B, and a hot one at that, the answer is 'Jesus Christ NO!'.
tbh if you want them get them, you shouldn't care what others think, its not their body, make it look how you want it to look.
The ironic thing being, I'd wager that the reason most guys get them done is because they do care what others think... they want to stand out and be noticed. They offer no functional value.
Right people of ocuk, I am thinking about getting the following 2 piercings and want your honest opinions please.
1) navel piercing, always liked it and think it's different on a guy, so would like it, opinions?
2) eyebrow, always thought it looked good and it popular ish aswel, although I'm thinking it might make me come across as a chav? Opinions please.
Get your willy pierced - that'll make you a real man. :eek:
I had a friend "straight" many years ago, that used to like sending me pictures via text message of his penis with various jewelry in his prince Albert piercing, one of the most disgusting things I had ever seen :(.
Can't see the attraction or "want" to do it either... then again I'm not a fan of piercings though it does suit some blokes - girls often look hot with a few strategic piercings though.
I got my eyebrow done and tbh, it doesn't look chav-tastic at all.
The piercer says to use salt water, but when I had my helix done, I was told savlon antibac spray (the clear one), I still have some spray, so just wondering whether it would be a viable option to use that?
