Caporegime
- 1 Mar 2008
Can't wait for the Zelda remake and Paper Mario.
Nintendo has released a handy FAQ detailing all sorts of information about the 3DS. We'll continue to update this page should any new information trickle out leading up to launch.
Release Date:
March 27, 2011 in the United States.
March 25, 2011 in Europe.
Price:
$249.99 in the United States.
Pricing will be set by retailers in Europe.
Launch Games: Nintendo has not confirmed specific launch titles. The company said it will release more than 30 games during the launch window between March 27 and E3 in June in the United States. Europe will see more than 25 games during the same time period.
Check out the list of launch window games.
Included in Hardware:
• Nintendo 3DS system
• Nintendo 3DS charging cradle
• Nintendo 3DS AC adapter
• Nintendo 3DS stylus
• SD Memory Card (2GB)
• AR Card(s) (view the cards using the outer cameras to play supported AR games)
• Quick-Start Guide
• Operations Manual (including warranty)
Characteristic Features:
• 3D screen, enabling 3D view without the need for special glasses and the ability to adjust or turn off 3D effect with the 3D Depth Slider.
• Stereo cameras that enable users to take 3D photos that can be viewed instantly on the 3D screen.
• New input interfaces including the Circle Pad, motion sensor, gyro sensor
• SpotPass, a feature that lets Nintendo 3DS detect wireless hotspots or wireless LAN access points and obtain information, game data, free software, videos and so on for players even when the system is in sleep mode.*
• StreetPass, a feature that lets Nintendo 3DS exchange data automatically with other Nintendo 3DS systems within range, even in sleep mode once this feature is activated by the user. Data for multiple games can be exchanged simultaneously.
• Convenient features that users can access without stopping game play such as the HOME menu, Internet Brower, Notifications, etc.
• Plenty of built-in software such as the Nintendo 3DS Camera, Nintendo 3DS Sound, Mii Maker, StreetPass, Mii Plaza, AR Games, Activity Log, Face Raiders, etc.
• Nintendo eShop where users can view trailers, software rankings and purchase software.
• System Transfer which enable users to transfer already purchased software from one Nintendo 3DS system to another. DSiWare purchased for the Nintendo DSi or the Nintendo DSi XL can also be transferred into a Nintendo 3DS system.**
• Compatibility functions where both new software designed for Nintendo 3DS and most
software for the Nintendo DS family of systems can be played.
• Parental Controls which enable parents to restrict game content by ratings as well as use
of specific wireless connectivity, 3D functionality, etc.***
*Some of these features may not be available at launch
**There is a limit to how many times transfers can be made. Some software may not be transferred.
***Additional features added through system updates may also be subject to Parental Controls.
Some of these features such as the Internet browser, Nintendo eShop, system transfer and the ability to download software and videos using SpotPass will be available after system updates are performed.
Size (when closed): 2.9 inches high, 5.3 inches long, 0.8 inches deep.
Weight: Approximately 8 ounces (including battery pack, stylus, SD memory card).
Upper Screen: Wide-screen LCD display, enabling 3D view without the need for special glasses. Capable of displaying approximately 16.77 million colors. 3.53 inches display (3.02 inches wide, 1.81 inches high) with 800 x 240 pixel resolution. 400 pixels are allocated to each eye to enable 3D viewing.
Lower Screen: LCD with a touch screen capable of displaying 16.77 million colors. 3.02 inches (2.42 inches wide, 1.81 inches high) with 320 x 240 pixel resolution.
Cameras: One inner camera and two outer cameras. Resolutions are 640 x 480 for each camera. Lens
are single focus and uses the CMOS capture element. The active pixel count is approximately 300,000 pixels.
Wireless Communication: 2.4 GHz. Enabling local wireless communication among multiple Nintendo 3DS systems for game play and StreetPass. Enabling access to the Internet through wireless LAN access points (supports IEEE802.11 b/g with the WPA/WPA2 security feature).
Recommended distance of wireless communication is within 98.4 feet. This can be shorter depending on the environmental situation. WPA and WPA2 are marks of the Wi-Fi Alliance.
Input Controls: Input controls are the following:
• A/B/X/Y Button, +Control Pad, L/R Button, START/SELECT
• Circle Pad (enabling 360-degree analog input)
• Touch screen
• Embedded microphone
• Camera
• Motion sensor
• Gyro sensor
Other Input Controls: Other input controls are the following:
• 3D Depth Slider (enabling smooth adjustment of the 3D level effect)
• HOME Button (brings up the HOME menu)
• Wireless switch (can disable wireless functionality even during game play)
• POWER button
Connector: Connector includes:
• Game Card slot
• SD Card slot
• Cradle connector
• AC adapter connector
• Audio jack (stereo output)
Sound: Stereo speakers positioned to the left and right of the top screen (supports virtual surround
sound).
Stylus: Telescoping stylus (approximately 3.94 inches when fully extended).
Electric Power: AC adaptor (WAP-002 [USA]). Nintendo 3DS Battery Pack (lithium ion battery) [CTR-003].
Charge Time: About 3.5 hours
Battery Duration: When playing Nintendo 3DS software about 3-5 hours. When playing Nintendo DS software about 5-8 hours. Battery duration differs depending on the brightness setting of the screen. The information regarding battery duration is a rough standard. It can be shorter depending on what functions of the Nintendo 3DS system are used.
Game Card: Nintendo 3DS Game Card. The size is approximately the same as Nintendo DS Game Card.
A portable game system with a 3 hour battery life?
Oh dear.
Oh dear.
If the PSP phat is anything to go by, it lasted far longer than that which was stated.
edit - Seems the viewing angles are very limited according to reviewers, which isn't good. despite that I'm still getting it as the games look fantastic!
When it says size is approx same as a ds card it doesn't mean similar space ie 128mb?
Oh dear.
As for the screen, in 2D mode the colors stand out and it's pretty crisp, but even a slight nudge on the 3D depth slider makes for a whole different experience. The viewing angle, which we actually commend during its two-dimensional presentation, drops to single-degree acceptability when the parallax display is put to use -- moving even just a little would cause the screen the flicker and the 3D effect to be lost or too muddled to enjoy. Expect to keep your arms locked in place while playing, and we'd advise against anyone trying to look over your shoulder to follow along. What's more, there's no instruction or guidance on how to adjust the depth slider for your eyes, and each game requires a seemingly different setting, so you end up fiddling with it a lot -- to what can be quite painful results. Our own Nilay Patel has had a headache since this morning's playing session, as has columnist-at-large Michael Gartenberg. We'd suggest Nintendo require each game to pop up a calibration screen with some saved settings that disable the slider -- otherwise we can see a lot of players just disabling 3D entirely.
I'm a sucker for being FIRST!!!
