*** The Official HTC Desire (Bravo) Thread! ***
Hold on, do I have to update the tables? I s-offd and flashed a table but I havent had to apply the radio through fastboot
EDIT: ah, actually, I've just checked my radio version and it's not updated (although no error occured when flashing it).
Do I have to apply the radio and RIL through fastboot (ADB)?
or, Radio through ADB and RIL as normal?
What boot animations do people have? I'm wanting a change from the boring Oxygen one, now that I've discovered how easy that Android Flasher program is to work.
Radio via fastboot (I used recovery as I don't use oxygen hboot) and then ril by recovery.
Just flash N1table back :p
I have over 100MB free using normal N1Table after moving apps larger than 1.5MB to Android SD, just keep the widget apps on internal mem and all is fine.
Means I can flash radio updates via recovery so saves me some valuable time. And by time I mean sitting on my ass :p
BTW, the radio is great! I fell asleep with wordfeud running, wifi on, phone had been off charge for 23 hours as of the time I woke up and battery was at 50%.
Fixed my issue before, was being a boob ;)
Had similar performance with the previous Radio tbh, which is great anyway. So much better than LeeDroid and other radio combinations though! ^_^
For example: I was listening to music for 30+ minutes whilst browsing in the morning on the bus the other day, and lost like 5% life!
Very impressed to say the least since this isn't even optimised that much yet!
Quick question. Was using an older version of LeeDroid and just updated to a newer one. I did a clear beforehand but when I flashed it still had some apps already installed. I backed up using Titanium but didn't restore, and looking at what was and what east installed nothing installed to the SD card was there.
So question, is this because I was using the apps 2 SD thing? If so, how do I clear those? Using AmonRa I believe.
looks like this will be the last rc as adam is gonna wait until the code comes out from the nexus1 update. although test roms will continue to be added too.
Oxygen seems great and all . But complete lack of proper Facebook integration, that stupid 3d gallery and 0.1 USB transfer speeds - unfortuanatly mean it's back to leedroid for me.
How do you mean USB transfer speeds? I've been getting 6-10MB/sec for several versions now which is only a bit less than HTC's Sense ROMs. Facebook integration is there through Facebook app but it's not as dug in as HTC's Sense (it was never meant to be anyway).
This is AOSP afterall!
I have made a decision to save up and get a Desire:D I was going to get a San Francisco but for another £100ish I can get one of these.
You are joking right? The kernels that have been released in the last week or so have completely messed up USB Mass Storage speeds. I barely get faster than 800kb/s when before it used to be at least 2.5mb/s. The ASOP kernels have never been as fast as the Sense ones, but you don't get the speeds you mention.
