the big bouncy ball thing (sorry don't know what it's called!)
Swiss ball
One more time for luck
If you make your own routine up at your level of knowledge you will really hinder your progress. Trial and error is one way of doing things, provided you have a few years to isolate the variables that you probably aren't even aware of. I'm a gym geek and have been reading around this subject for probably 5 years and I still wouldn't consider myself to be anywhere near an expert.
Funnily enough, that Scott Herman chap is EXACTLY who I had in mind when I read that you found a routine on youtube. That guy is a tool. Just to make a brief point, on what basis did you decide his routines were good?
There is no "cheat" way of growing muscle/whatever your goal is, the only answer is a lot of time and a lot of hard work and dedication.
As a noob training on your own, the best thing to do is do a routine based on some simple exercises. Then look on youtube or ask on here about the best way to perform those exercises and spend a week or so with light weights doing the reps slowly so you can learn the movement properly.
I know I'm a pain in the rear guys! It's just I would like everything laid out in-front of me all of the time and I guess It's not going to happen when it comes to weight routines. I promise you I will start with the sticky on here and see where it goes. I guess I'm kinda nervous about being on my own in there, so don't want to try anything new. (Terrible Gym)
So I am going to start taking this seriously, as boxman and benny said I will start to cook a bit more and learn about different foods and how they affect me.
And to answer your question icecold, I basically made the decision that he was good by his body. I have no idea if the stuff he does is any good or not!
The 3 day structure is:
DAY 1 – PULL
Deadlifts or Power Cleans
Barbell Rows, Dumbbell Rows, or Wide Grip Chins
Barbell Curls, Close Grip Underhand Chins, or Hammer Curls
DAY 2 – PUSH
Incline or Flat Barbell or Dumbbell Bench Press
Barbell or Dumbbell Shoulder Presses
Tricep Dips or Close Grip Bench Press
DAY 3 – LEGS
Front or Back Squats
Barbell or Dumbbell Stiff Leg Deadlifts
Calf Raises (3x12) - only if a seriously lagging bodypart
Weighted Crunches or Weighted Hanging Leg Raises (3x12)
You could include your leg day on the push/pull, adding your squats to your push day and SLDL's to your pull day and then adding calf raises and your crunches/leg raises to which ever day you want. This would give you a slightly higher frequency for legs which might be useful if you're doing a lower volume workout.
Workout A:
Shoulder Press
Leg Press
Chest Press
Tricep Pushdown
Calf Raise
Workout B:
Hamstring Curl
Seated Row
Side Raise
Pullup/Pulldown
BB curl
Ab isolation
and start to lift heavy
I'd say to start the A workout and then have a day or 2's rest, then the B and then again a day or twos rest. When you feel recovered start the cycle again. In the beginning you might find it'll take you a while to recover from DOMS (aches) so will just want to do each workout once a week for the first 2 or 3 weeks but your recovery should soon speed up. In which case a rolling Monday, Weds, Friday will work well. For example:
Monday: A
Weds: B
Friday: A
Monday: B
Weds: A
Friday: B
and so on...
Are you for real sponge? Every bit of advice people have offered you have ignored.
Honestly mate you need to change everything and start again or your going to end up wasting 3 years of your life training and then realise youve been doing it wrong all those years and then start to do everything the guys are telling you above.
I have a 3 day split, chest and tris, back and bis, legs and shoulders (sometimes split legs and shoulders if I have time) There is also the stronglifts as people keep saying but my 3 day split works well for me.
Start off with light weights and keep your form right. To put on mass though you really need to be training your legs hard.
And you have been suggested to look at the sticky and a few other well known routines.
You clearly have not taken this advice![]()
Will start it off tomorrow afternoonCurls at 20kg and deads at 30kg? Your deads should be much higher than what you curl.
\o/ yay!
Remember to go nice and light with the weights initially.
Enjoy it![]()
