Those are the same mods I use, except for the nano suit. Is there any point to that in single player?
Like you, I found these mods caused a marginal FPS drop. I'm still undecided about the HD Foliage one though - far off trees look like just empty branches, the leaves don't get drawn. It doesn't look as good. Maybe there's some setting I can tweak?
I did have the large texture mod as well, and it does make a dramatic difference in places, but found in the most demanding places, I was getting a big FPS hit. Without it, I can run on Very High, smoothly. With it, I can't even manage High without frequent stuttering.
Cool, they look worth checking out.
I like it a lot personally. Your hands look a lot better looking
and more HD looking, also whatever way you customize your suit it will also look like what you picked in all of the cutscenes as well, and also if your using a gun where you can see your entire body so you will see the suit that you chose/customized and also you can change the colour of your visor.
Nope, I didn't say that
, mine seem to remain roughly the same, and plus gameplay seems a lot smoother than just normal crysis for me for some reason.
Haven't had a problem with the HD foliage one, works great for me and haven't had the problem that your describing, not too sure, maybe just mess around with the settings and your FOV.
Yeah, I was having a look at rygels texture pack at 2GB, but was worried about the FPS dropping quite a lot and I can't really be assed to download it and apply it
, happy with the way I got crysis at the minute. Will apply it sometime this week along with some other mods.
The HD foliage mod should still be rendering distant tree leaves. There's something wrong there.
I've played the resort map, it's very good. Another you might want to check out by the same guy is Cold Mountain.
Yeah, it is good fun, but my god, I can't stand the script for it
, it is awful IMO, and I can't skip those scenes either
, but apart from that it is good.
Personally I really liked this one, very short but really good fun:
http://www.crymod.com/filebase.php?fileid=4766&lim=0
Looks very nice indeed, will try it out sometime this week as well.
Thanks
Really can't wait for crysis 2 after playing crysis and seeing videos for the second one. Multiplayer looks epic as well, just hope it is a good port.
