You are a lucky dude
, do you get to keep them, hows that work then?
Not all the time, they normally send the sample for a few weeks so I have limited time to bench them.
Ok so for fan speeds:
HIS HD6950
At 800/5000MHz: idle = 28% load = 37%
At 865/5500MHz: idle = 28% load = 40%
Unlocked at 8800/5500MHz 1536 Shaders: idle = 29% load = 51%
Idle volts: 1.0V
Load volts: 1.1V
Load volts unlocked: 1.175V
The fan only becomes audible above my case fans at 45% but it doesn't get intrusive till it reaches around 50%
ASUS HD6970
At 880/5500MHz: idle = 28% load = 51%
At 949/5896MHz: idle = 32% load = 57%
Idle volts: 1.0V
Load volts: 1.175V
Load volts when overclocked: 1.24V (voltage tweaked)
The fan only becomes audible above my case fans at 40% and becomes quite intrusive at 52%. It reaches blow dryer levels at over 60%
Inno3D GTX570
At 732/3800MHz: idle = 49% load = 67%
At 901/4200MHz: idle = 49% load = 70%
Idle volts: 0.988V
Load volts: 0.963V
Load volts when overclocked: 1.063V (voltage tweaked)
At 49%, it can barely be heard and even at 67% it is slightly audible but not intrusively so. It becomes more of a soft whirring noise.
ASUS GTX580
At 782/4000MHz: idle = 51% load = 69%
At 903/4220MHz: idle = 57% load = 74%
Idle volts: 1.014V
Load volts: 0.992V
Load volts when overclocked: 1.180V (voltage tweaked)
Again, it's quiet at 51% and only becomes audible at around 60%. At 74%, it gets intrusive.
Just as a note, those were recorded after 5 minutes of running MSI Kombustor and because I use dual screens, all the cards are clocked higher than the default 2D speeds at idle.
Edit: added flashed HD6950-HD6970 results
