Which card would be better for gaming at 1680x1050, and what is the better card overall?
Indeed go buy yourself one Dell UltraSharp U2410 24". It's on sale, and for only *coughs to cover actual price* (£437) you can have it
If your still running the card in your sig you dont need to upgrade for 1680
+1
If your GTX 460 768MB is OC'd to around 850mhz then I don't think its worth upgrading to either the GTX 560 or HD 6950 - I'd get another GTX 460 and run them in SLI.
No offense, but your current GTX460 768MB would be more than enough for your res (especially if you overclock it) and would easily able to last you till the end of the year...when the next gen card on 28nm process get released.
I think you should save your £200 and spend it at the end of the year on a 28nm process card instead (which should be even faster).
Great advice on SLI (NOT)
Your current card is more then good enough at that resolution, what you should do is save up for a new monitor with a higher resolution and wait till the next generation of graphics cards on the 28nm process and then update the graphics card. You will feel like you have been robbed if you upgrade the graphics card now or add a 2nd one to SLI at that resolution, you just won't see the benefits.
I was thinking today and I wondered if I should go SLI or get the 6950, probably sli though, and getting a couple monitors and doing 3d surround/eyefinity.
should I do that or get a bigger monitor?
Only you will know if you should do it or not. There are plenty of detailed articles around that will allow you to figure out what's best.I was thinking today and I wondered if I should go SLI or get the 6950, probably sli though, and getting a couple monitors and doing 3d surround/eyefinity.
You questions are getting silly now imo, go do some research and curb that impulse buying mode that's clearly going on in your head today.![]()
