Can you use drones? I guess you could stick a MWD + Overdrive on an incursus - hope the rifters use the lows for tank/gyros and stay out at disruptor range letting drones (or drone) and rails (might not track well enough but if they are silly enough to try and burn straight towards you won't be an issue) do the work. That might not work so well against other frigs tho and rifters might kill your drone dropping dps a lot and theres the risk the rifter pilots might be able to get the edge overheating.
Or you could try a tracking disruptor w/ optimal range script and staying at 4-5km... all in all gonna need a lot more experience than I have at frig warfare tho to field gallente against rifters.
