1\ Pluto is still a planet as far as I am concerned.
How nice for you. What about the other half a dozen objects that used to be considered planets until more was learned about them? Do you consider them to be planets too?
According to the Planet X/Nibiru/blah blah conspiracists, it's at least a planet bigger than Earth. Some of them think it's a brown dwarf!
Take a look online for the end of the world Nibiru people.2\ Who said it was hitting earth? Sumerians / Egyptians didn't
But it's where those people are getting the timing from.3\ Its not even mentioned by the mayans, their calendar ends its long count that is all.
The orbit of Pluto? No, it isn't. It's just under 248 years.4\ It is 3600 years according to the texts
Which is another reason why it's all bull.Check your facts your getting Sumerian and Mayan all mixed up , lol a few 1000' years difference and a few 1000 miles as well.
Also...in what way do you think your post counters the argument that an incoming object at least as visible as a planet bigger than Earth would not be easily detectable 2 years out? Or how it supports your argument that the fact you can't see Pluto from Earth with the naked eye proves that an incoming brown dwarf 2 years out would be invisible?
