Not much overclocking for me, seems there are some issues with the bios on the board I have (P8P67-M Pro), most notably the fact that there is no simple way to change the cpu voltage![]()
I don't want to spend loads of time overclocking only to have to do it all again once a bios update is out, so have just set it to 4Ghz for now.
http://www.xtremesystems.org/Forums/showthread.php?t=265765
Was going to get a Msi GTS450 which there around $95/105
But u can get a GTX460 for $10 more. I cant deside between Msi or Asus, both seem to have good coolers on them
Im still sorting out the rma for 9800GT![]()
). http://www.tomshardware.com/reviews/geforce-gtx-460-roundup-gf104,2714-18.htmlMSI has the coolest-running card, likely due to its huge GPU cooler. Yet its full-fan tests weren’t as spectacular. Asus’ fan supports higher-speed operation, resulting in a relatively chilly GPU temperature that’s available to anyone who can tolerate its higher full-speed noise.
[17:24:26] Completed 250000 out of 250000 steps (100%)
[17:24:37] DynamicWrapper: Finished Work Unit: sleep=10000
[17:24:47]
[17:24:47] Finished Work Unit:
[17:24:47] - Reading up to 52629024 from "work/wudata_07.trr": Read 52629024
[17:24:47] trr file hash check passed.
[17:24:47] - Reading up to 42712204 from "work/wudata_07.xtc": Read 42712204
[17:24:48] xtc file hash check passed.
[17:24:48] edr file hash check passed.
[17:24:48] logfile size: 213777
[17:24:48] Leaving Run
[17:24:50] - Writing 95722949 bytes of core data to disk...
[17:24:52] ... Done.
and then:[20:37:47] Error: Missing work file=<>
[20:37:47]
[20:37:47] Folding@home Core Shutdown: MISSING_WORK_FILES
[20:37:50] CoreStatus = 74 (116)
[20:37:50] The core could not find the work files specified. Removing from queue
[20:37:50] Deleting current work unit & continuing...
[20:37:54] Trying to send all finished work units
[20:37:54] + No unsent completed units remaining.
[20:37:54] - Preparing to get new work unit...
[20:37:54] Cleaning up work directory
[20:37:54] + Attempting to get work packet
Biffa, What clocks are your 470's running at ?
Didn't you say something about 850 in another thread?
