Hey, after building my new machine and powering up I get a message saying:
"Reboot or insert proper boot device"
I thought maybe I just need to boot the windows cd instead.
So I went into bios and changed the boot prioties so cd_dvd drive is first. However I still get the same message.
I'm using the Foxconn P67A-S mobo and a samsung spin point F3 HDD.
Also the smart LED says "AE" which is a bit worrying. The manual doesn't explain what this means and Im having trouble finding out what to do on the internet.
Also the bios does detect all the drives, so it can clearly see them?
Sorry two questions in one:
Also having to use stock cooler (makes me feel dirty) because cooler master came with a fail screw.
But cpu temp seems high in the bios to me. Seems to start at 35 ish and creeps up to 44. Bit worried about it, not sure if it would go higher if I left it longer..
Is this normal? :s
Thanks in advance
Is this normal? :s
Thanks in advance
