- 22 Mar 2009
Have you got the date wrong as it look 30th January to me ? Should be 29th ?
didnt set it up in the bios mate![]()
how does this compair to the akasa venom ?
please remember - the results, whilst they look a little dissapointing, this cooler really shines when it comes to noise
there really isnt any cooler on the market as quiet as this. the noctua comes close but doesnt look as good and also is far louder.
but the results would not be far off considering the volts.
make no mistake, this is a very good and very capable cooler.
put some higher rpm fans on this cooler and it would really shine but would defeat the reason it is made
in my honest opinion. keeping a volted bloomfield at those temps at that noise level would be difficult to achieve for many other coolers out of the box.
i am personally quite impressed.
remember, this is using the stock TIM as well.
you would yeild better results with a tube of mx3 without a doubt
hope my analysis helps a little![]()
Ah - I was thinking of portrait and landscape LOLThose arnt horizontal![]()
you can always lay a tower case flat on its side![]()
