(!) Aircooling badboys (!)
27 Jan 2011
London
Aircooling an Intel i5-2500k that I plan to buy in the next 2 months.
Planning to do some pretty solid overclocks on it.
Choices:
Akasa AK-CCX-4002HP Venom CPU Cooler £35.74
Titan Fenrir Evo CPU Cooler £36.76
Cooler Master V8 CPU Cooler £45.95 inc VAT
Noctua NH-U12P SE2 Dual Fan Quiet CPU Cooler £56.16
A little over my budget, but if you guys really recommend then I'd save up a bit more.
by the way:
I have seen fan controllers available to purchase on OC.uk
If I bought an Antec 900, would the fan controller be compatible with the stock fans installed?
The Akasa or Fenrir probably offer best bang for buck. The other two cool better, but not worth the extra £10/20.
Be careful you don't lose sight of price/performance. The high end air coolers are all expensive, and you don't get a great deal extra overclocking for your money.
The Noctua for example would not make a 2500K overclock to the levels a 2600K would clock to with the stock/cheap cooler.
But if you want to overclock for the fun of it, and you're not really concerned about getting the exact best price/performance point then that's the way to do it.
The "king" at the moment is the D14 and by all accounts it'll be a while before it's beaten. To be honest I don't see how more could be done, the technology has incoroporated heatpipes, but basically it's all about maximum surface area.
If you already have some fans I would say the thermalright venomous-x. It is roughly £40 and I had it for a while and got some amazing temps with it! Only reason I got rid of it was because I went for a custom watercooling loop :)
The Noctua NH-D14 is a tremendous cooler but I wouldn't call it the "King" since the Thermalright Silver Arrow can easily match its performance while remaining quieter.
I agree with that. The Venomous X is an excellent performer for its price.
If you want to stick to your budget, then the Thermaltake Frio is also worth considering and already comes with two fans.
thanks for the responses
I'll look into that
Titan fenrir will do more then an adequate job at cooling that chip, even at 5Ghz.
Noctua would be silent overkill :)
Is the fenrir quiet?
Well, since the i5-2500k performs nearly as well as the i7, I went for the i5. However, do you think it is worth it to spend £80 quid more? Is the i7 more future proof?
+1 for the NH-D14 if not just for cooling but the acoustic performance. As I found even 18dB drove me nuts after a few hours and my NH-D14 is hardly even audable at a humble 12dB.
I've recently installed teh Fenrir Evo into my rig and I've gotta say, I'm impressed. I can't hear it over my case fans and its keeping my q6600 at 22deg idle. Although it's still at stock, the fenrir doesn't allow the cpu to reach 40 degrees when prime'd.
I'm using a Akasa Venom and its awesome! With a 3.6GHz OC on a 1055T my idle temps are around 22C causing the fan on the headsink turns off, full load 48C and the fan is still inaudible over my 6970
I have to say that I love my D14. So quiet!
NH-D14 Just built my new sandy bridge with this cooler Great temps and no noise from what i can hear.
Thanks for responses.
I am debating between the Noctua and the Akasa Venom
