Q6600 keeping my room warm!!
talking about heat 1090t @ 4ghz and 6970 and window opened now not sure how it will be in summer probably to hot to handle :rolleyes:
Guys
A few hundred watts of heat coming out your PC is not going warm your rooms up
Right, so a few hundred watts of heat is going to do what, exactly? Lower the air temperature in the room?
Seriously, in a modern-ish/reasonably insulated/not too draughty building, those 'few' hundreds of watts of heat make a massive difference.
Once you factor in warm components like Q6600s and power hungry GPUs running at full load, even 24/7 for number crunching, you soon need to start turning down/off radiators.
spot on, my mates [email protected] could heat a room easy.
my q6600 used to provide a slight boost, my new sandy bridge doesn't help at all.
Really notice it at a LAN with 4-5 PCs in the same room.
Does any one have any indication of how much power Q6600 consumes when running at 3.2-3.6Ghz? Also how would this power consumption compare to the i core series and/or sandybridge?
My Q6600 B0 @ 3Ghz system draws just under 90 watts at the socket, while playing games it goes to about 220 watts.
Looking to upgrade to SB so will be able to compare, just not sure when that is tho, sooo tempted lol but my Q6600 seems to do everything I need. I might just buy the I5-2500k and frame it on my wall :D
Been running a q6600 at 3.60 for a couple of years. It used to have an external radiator which was like an under-desk heater :)
Replacing it with an i7 sb this week. But only because I found a deal which included a corsair power supply and ram, thermaltake case with hotswap drive bays, asus p67 MB and DVD writer for under £500, otherwise I would have kept it for longer :P
Anyone ever done the figures on how much it costs to heat a room with a PC vs a radiator? Q6600 heating could be the future!
must confess, between my OC-ed Q6600 and my 4870X2, this computer chucks out a fair bit of heat, so much there is a patch on the wall behind, starting to go gradually lighter! :D
What device are you using for measuring the power draw at wall socket?
