I popped down to the Pistonheads meet on Sunday with Gibbo and he was generous enough to let me pedal his pride and joy there and back. I managed to avoid sticking it on it's roof in a field, usually the end game when you release that world famous line of doom.............."WATCH THIS!!" It is a very accomplished road rocket and an interesting comparison to my RS4 which though not really a direct competitor is a similar configuration.
First thing to say is it feels quicker and seems to pick up speed quite a lot quicker than my RS4, certainly up to big numbers (which of course we never saw...) and though we didn't do any side by side comparisons I feel confident the Evo would show the RS4 its heels until the speeds got very serious at which point I suspect the RS4 would be sitting on it's limiter at 160mph. It does use it's gears up very quickly and REALLY needs a 6th gear for motorways, something I went searching for time and time again, though luckily not finding reverse in my search! It's gearing really means lag is never an issue and it is much more grown up than some of the earlier versions I've driven.
Gibbo's car is still running sponges for tyres and they did show this when pushed hard into a fast bend such as a well known bend at 'some' speed. This was interesting as I entered the corner at a speed my RS4 would be on rails and the Evo was moving around a bit needing some throttle input to keep it all together, all down to tyres no question. Also I have a bit of a play on a well known island to test understeer/oversteer and it was a little confused for a bit but it was easy as pie to bring in back in line. Like the RS4 the Evo REALLY flatters the driver, perhaps even more so. It allows you to take real liberties that in many cars would make you dead of deadness.
Steering's not great, certainly on the tyres it has on and I'm sure it will weight up with the better tyres on but it's very light and lacking in feel. First thing I noticed and the brakes needed to be worked to work but they are OK once up to temp. Damping was most impressive and I think shows how the car has moved on and grown up. It might have lost some of it's sharpness and having needed 30K's worth of dental after a long run in a Tommi Mack version some years back I was really impressed by how well it dealt with modern roads. REALLY well planted and damped, soaked up bumps easily and this added to its cross country capability. It is, make no beans about it, about as quick as a road car gets from A to B, very impressed by it but bugger me needs a 6th gear as my ears are still ringing, though that might be down to Gibbo's S Club 7 albums.
Thanks for the run Sir, enjoyed it and think your car is rather splendid and very quick. Get some serious tyres on it and I'll have another go and see if we can get it on it's roof in that field!
