The whole thing is a bit ghetto at the moment tbh.Sorry if this has been covered earlier, but what have you done about the wiring (or is there a version of the P400 with the required socket)?
My P400 SFF-8484 connectors are on the rear of the card so i've got 2 SFF-8484 to SATA fan out cables, one 45cm and one 70cm. I've removed the existing back plate of the drive cages and shifted 120mm rear fan from the inside to outsite to give me more room to work with behind the drives. Using the 70cm cable + power extensions to 4 drive slots i can get drives within there caddies in and out of the front (just). It's not pretty but it's working for now.
I've ordered the correct SFF-8484 to SFF-8482 cables (slow boat from China) and i'm going to mount them into the back plate. This will mean the drives caddies function as intended and less faffing.
I have one of these (different brand, but same system) in the 5 1.4" bay:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-037-BT&groupid=701&catid=14&subcat=72
Blue Peter style i've used self adhesive velcro to mount a piece of cut plastic on to the top of that (red in the piccy below), then used more velcro to mount the 160gb 2.5" drive to that. It's good because the 2.5" OS drive gives off virtually no heat and is isolated from any vibrations caused by me using the trayless caddie. All the squeezes nice under the case lid and means i get RAID 5 with 5 x 3 1/2" drives inside the machine + seperate OS drive which is imaged so can be replaced quickly if needed.
Once i've finished the build fully i'll post up some pics properly.
