Anyone on 360 tried the new Zombie map in the MapPack and got any comments on it?
First thing - it is HUGE. Utterly massive. I have played it 7/8 times and still have very little idea where everything is. It almost seems as if they have tried to hide the perk machines & box, although the box is slightly more obvious. (When you are on the 'lander' you can see a beam of light pointing out the box)
Everything is black & white until you turn the power on, which is a bit odd.
Zombies are only 'standard' i.e. no annoying crawlers which emmit a gas when you kill them. Dogs have been replaced by lots of very small monkeys. Instead of the fog when dogs arrive, the sky turns red and there is some kind of mental meteour storm, it is mental.
I can't quite work out the monkeys yet, they seem to pose little threat to killing you really, and are fairly easy to kill, although every round my perks dissapear and I have to buy them again.
Someone mentioned the monkeys destroy / damage the perk machines. I'm not sure if this means that you lose that perk if they damage the machine.
There are two new perks: One is called PHD Floper and I have no idea what it does. Some say when you dolphin dive it creates a mini explosion. The other is very similar to lightweight.
There are a couple of new weapons: Black hole device which sucks all the zombies in & Russian Doll which is a colourful cluster bomb. The former is very good, a lot better than monkeys, the latter is fairly rubbish.
You can also pick up a death machine as a bonus like double points, instakill etc which is good fun. It is timed like the others.
Finally, instead of the teleporter, you now have a moon lander type thing which flys round. The frustrating thing is, as soon as you activate the lander to take off, the zombies seem to instantly know where you're going to land and run to greet you when you get there!
