Ok, so I have a question, or a conditional scenario I would like some thoughts on if you like.
If you were offered a fuel card by your employer with one major caveat, it can only be used for diesel, yet you currently have a nice petrol car, what would you do?
Obviously this would mean having to switch to a car powered by the devils own fuel, but the savings you could make on not actually having to pay for fuel at the pumps out of your own pocket to the tune of 150-170 a month, give or take would weigh very heavily on this decision.
I suppose the crux of it is, all things considered and accounted for, to basically avoid paying for fuel out of your own pocket, or most of it anyway, would you switch to a diesel car in such circumstances? ...assuming you have a car like mine, a Jaguar XJ6 3 litre petrol. So all things remain the same, the cost involved is the cost of switching to a diesel car basically ...the cost of fuel however being removed will off-set this in time, more than eventually.
I know with these kind of things it's usually a case of petrol or diesel ...so how many miles do you do? ...taking into account the typically higher cost of equivalent diesel models and the often higher cost of ownership due to modern diesels tendency to eat injectors, turbos and what not and the higher cost of diesel at the pump ..this usually means that for people that do anywhere near average mileage, it's actually not cheaper at all to buy a diesel.
But if you take the cost of the fuel out of the equation entirely, it starts to paint a different picture I think.
The money saved on fuel could even be added to slightly and used to purchase a newer car in theory.
So there are really a few ways of dealing with this that I see;
1 - Ignore it and carry on as you are.
2 - Find a similar value diesel car and switch to it and save money, however getting a car of the same quality and type but with a diesel engine can't really be done for the value of the old car, it would require money to be spent unless you downgraded. This is probably around 6k ...could spend a bit extra and still see savings quite quickly I suppose.
3 - Purchase a newer more modern and absolutely equally nice car to the one you have, but finance it monthly, mostly using the money you are saving from not paying for petrol ...with a bit added, so something in the 15-16k bracket most likely.
So scenario 3 is obviously the most interesting but it involves spending a fair amount of money and option 2 will actually save money in the here and now, although there is no particular use for this money other than saving it for ...whatever.
Personally, I don't think it's as simple as it first appears, especially when you have a car that simply can't be touched for the price, so the only way to really move forward is to spend mnore than the money saved per month on something much more expensive. Or one could buy a 2 litre diesel something or other and save lots of money on motoring ...but have a boring run or the mill car that holds no interest at all. Or I guess there is always the option of a much older diesel car that is nice and a bit more interesting like a Mercedes S320 CDI or such ....but this has massive liability written all over it, so you might save doing this ...or it might break and you don't save at all.
