Now that IS brute force.But what about getting two of them...argh.
TBH Deus Ex 3 looks like a right let down.
The Twin Forza lets the 470 run a few degrees cooler, but it does not take care of heat, it blows it around the inside of your case. Within a case that has poor airflow, these cards may run hotter than reference coolers which expel most of the hot air out of the back. For SLI setups, Twin Forza's can be much worse, reusing and further heating already warm air.It's a good deal, solid peformer and good clocker, the only issue with the GTX470 is heat and the Twin FrozR takes care of that.
I would favour pushing cool air in. That worked best for my old GTX460 SLI when I used the same case. You will still recycle hot air around the case, but it will keep you GPU's coooler and the top 140mm fan will expel most of the warm air (some will also be routed via your CPU cooler as wel, rasing CPU temps a little). The 300 is reasonably good, so heat should not be a problem.I have an antec 300, should my side fan be pulling in cold air or taking hot air out?
You'll be fine. I was just pointing out that the Twin-Forza does not completely solve 470 cooling, counter to what many have written here. It is a very good card which has some advantages and some disadvantages.Just been looking at a 140mm PCI exhaust fan. That may be an option if I get any issues.
